How do unlink my Google account from my old phone
How do I unlink an old Google account from my phone
No, DO NOT reset the phone to factory settings yet or you may have the added hassle of needing to enter your Google account details that were previously linked from the device.
First of all, make sure to enable developer options by tapping on build number 7 times which is located in Settings, About Phone, Software Info.
Then enable OEM unlock in developer options before factory resetting the phone via settings or recovery menu.
Also you can just remove the google account via the accounts section of the settings, the remove account is under the 3 vertical dot menu button on the top right when you select the google account under syncing.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 776
1 Comment
Reset the phone to factory settings, anything you put into it will be gone. Also, remove any micro SD card if you put one in the phone. You can put that on a computer and make sure it is formated clean before you put it back in the phone.
by joe
