SSD Upgrade Gone Wrong...Help
Quickly:
Samsung 850 Evo 500GB Installed.
I used a bootable usb of High Sierra and a sata-usb adapter. I formatted SSD and installed clean OS X High Sierra. Then using Disk Utility Migration I copied all files, apps and other stuff from machintosh HD to SSD. Before I swapped the drives I booted from SSD externally and it worked like a charm. I then swapped the old Mac HD with the SSD and ran disk utility again. I selected Samsung SSD which was now inside my laptop as the startup disk! So I pressed restart and my MacBook Pro will load the full bar but never actually leave that screen. Sat and waited for 3 hours. Tried repair on drive and had no issues. Started again and still it loads the bar and stays at that white screen with the Apple logo(full bar below). I have read all the posts and i’m Not sure if it’s the cable or a faulty SSD.
Mise à jour (13/01/2018)
I am finally able to post my results and solution to my issue. @avanteguarde , Thank you for your help. @joesipaq , Thank you for your help as well. After i received my Sata cable replacement, everything worked like a charm!
1 Comment
I have attempted everything but clean start on my Machintosh HD and then repeating the SSD Upgrade proceedure. I will do this now and post my results on here. In the meantime, does anyone know if my SSD will be discoverable once I have a user and am logged in, because it is not discoverable as external at the moment.
by Georgi Bilyarski
