Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
solder old nand flash on new motherboard
Hi,
My samsung galax s6 took water damage, but I want to retrieve the data on it. I already tried to replace the battery and usb connector unit. Both didn't work.
My last resort would be to buy a cheap 32GB mortherboard on aliexpress. And remove the 128GB nand flash from the broken phone and solder it on the 32GB motherboard.
1. Will this work in theory?
2. Can this job be done by someone with next to none soldering experience? btw, I dont care if i will screw up, because I see it as the last resort anyway.
3. Or do you have other suggestions to get the data back, which are not expensive.
Thanks
Add a comment
Is there any way to fix the water damage?
Electronics Water Damage
1 Comment:
Thanks, I already cleaned en submerged the boards with isopropyl alcohol. I couldnt really reach the processor, nand unit etc. though, since they are under a protective shell.
by
Add a comment
did you already try this? I'm in the same boat. I will try this today a let you know what happens
1 Comment:
Did you have any luck with this?
by
Add a comment
Add your answer
Mar Do will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 378
