Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 front camera not working
Hi guys, I have an iPhone 6. Front camera not working, flash and rear camera work fine. Can anyone tell me it’s the camera Ic U2301 or something else? If camera Ic U2301 is faulty, both cameras should stop working at the same time. Since rear camera works fine, I really don’t want to touch the camera IC unless I have to.
Score 2
1 Comment
Does the Earpiece speaker and proximity sensor work? Do you have another test screen to see if it is the Camera flex assembly or a logic board issue?
by
Add a comment
Most Helpful Answer
Check voltages and filters in pics, also check the pins on FPC in Diode Mode
Score 4
4 Comments:
Many thanks Michael. I will check voltages later. I have a question here, wonder if you can help: if the camera IC U2301 is faulty, is it possible that the rear camera still works? I always thought if U2301 is faulty, both cameras will stop working altogether. Is it true or not true?
by
True, it feeds the 2.85v line... So my first thought would be to check the FL1123 (PP1V8 line) or FL1144 (PP2V85_FCAM_AVDD_CONN), but can't rule out damaged pins, faulty front camera or flex...so I would verify voltages and then test the FPC pins for resistance to see if it may be another line.
by
Hello, was this problem ever solved? I'm having the same problem right now, also with an iPhone 6.
by
try testing the voltages and resistance as described above
by
Add a comment
tengo un problema todos los voltajes aparecen pero el 2.8 esta solo por un momento a la hora de activar la camara frontal y despues desaparece cambio ldo pero sigue igual los condensadores no muestran corto y el filtro funciona bien
Add a comment
Add your answer
phonestore.uk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 9,867
