Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Changed U2402 and now NO POWER?
So i got a iphone for touch ic today and changed u2401 with no problem checked the touchscreen everything seems good but still not responsive so i went on to change u2402 after i changed this it will not power on I am so confused right now so any help would be appreciated
Add a comment
1 Answer
Most Helpful Answer
Go back to where it last worked. Remove U2402, make sure there are no bridges or components knocked off their pads... try to power up without the u2402 and see if you have power, if not, then remove u2401. Before putting back the IC's make sure pads are cleaned up and nothing is bridged and you have a good reball on both IC's. Then, make sure you run the M1 jumper on U2402 before placing it back. U2402 is the problem with no touch the majority of the time with u2401 the main cause of the grey flickering bar on top
Feel free to ask any questions
Score 3
Add a comment
Add your answer
Julio will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 108
