The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
iPhone screen flashes, is it a brick?
Hello, my iphone will not charge or is not recognized by itunes, should i exchange battery and sub charger?
When connected to wall mains, screen flashes with lines.
When connected to computer flashes the Apple logo.
Flashing iPhone 2g
Score -1
Add a comment
Chosen Solution
The cheapest option here is to replace the battery. At this age the battery has probably reached the end of its life. Not booting/flashing on and then off can be a sign that battery is dead as is not charging. Rather than declare death of logic board I would replace the battery and then go from there..
Score 2
1 Comment:
I have tested DFU Mode with no luck.
I am going to buy a new 1350ma battery to install.
I will test too with a new charging cable.
If it was a dead logic board i think it did's even show apple logo.
by
Add a comment
This is probably a dead logic board, You could try putting it into DFU Mode, and restoring it with iTunes, but this is a sign of a dead logic board, or a corrupt baseband, both of which are virtually unfixable, without replacing parts.
Add a comment
It is working now.
I have ordered a new battery for $2.50, desoldered the old one and soldered the new one. In secounds i was working in full with the iphone.
Thanks pollytintop for the help.
Hope is the last one to die.....
2 Comments:
Brilliant. Got to love the cheapest option every time. Really pleased you stuck with it and fixed it, glad to have helped.
by
Where did you order the new battery? Can you send me the link. I have the same problem with my iPhone first generation phone.
by
Add a comment
Add your answer
diasje will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,927
