Exact size of the screws holding the heatshield
I'm talking both the 6 Y000 to the sides and the one philips next to the Touch ID.
Unfortunately they are not mentioned in any guide with their respective length.
The guide for the iPhone 7 Plus states that it uses 1.1mm Y000 for the 6 shield screws and one 1.8mm philips. Since most of the other screws seem to be the same length my guess is those will be identical as well.
In this guide you will find all of the screw lengths for the screen assembly, except for the 6 identical screws securing the sides of the backplate. By exclusion, you should be able to figure everything out.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 328
2 Comments
I have come to the same consensus you have, I cannot find any screw refrences anywhere other than this: www.ifixit.com/Store/iPhone/iPhone-7-Screw-Set/IF332-034-1, which doesn't even list lengths! Sorry, but you might be stuck. Good luck, hope you get your screws sorted out.
by Reed Crosby
It would really help if IFixit would provide a screw id with its replacement packs.
by Laura Moon
