Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
311 Questions View all
Questions on upgrading drives (HDD Vs SSD) and how.
Dan, thank you for alot of great useful information. I plan to update my 2011 iMac with an SSD, primarily for performance (Photoshop, etc). From a performance perspective, is there any benefit of one config over the other?
- Replace existing HDD, adding thermal sensor
- Add SSD behind optical drive as a second drive, migrate to SSD and make this the primary/boot drive
My iMac has had what I suspect is a thermal problem, as the fan is almost always on high speed. I've suspected a FW problem with a sensor, somewhere, and after reading the above threads wonder if this is related to the HDD fan. If I 'add' the SSD, the existing HD and sensor remain, and my fan always at full speed. If I replace HD, and add the inline sensor, I wonder if this problem goes away? Suggestions on diagnosing this fan issue? Thanks.
6 Comments
@jvemo - Jon, Both ports in this system are SATA III (6.0 Gb/s) so it makes no difference from a performance perspective which you use. If you swap out your current HD you'll loose the benefit of the all that storage. So I would lean to adding the SSD Vs swapping out.
As to your fan issues lets see if we can resolve that. Is the current drive in the system the original HD or a replacement drive? If it was a replacement drive and its not Apple logo'ed then you'll need to install the OWC thermal sensor cable.
When I first wrote the answer here Seagate had installed the custom firmware on there SSHD's I guess Apple found out and had them pull it ;-{ So discount the part of the answer.
I would recommend getting this great app: TG Pro for less than $20 US its worth it! It should help you isolate out whats happening here.
Once you install the SSD run the OS installer and then use the Migration assistant to move your User accounts & Apps to the SSD. Then restart the system holding the Tab key to gain access to the startup manager select the SSD and then go into Startup prefs to lock it down.
by
Thanks Dan. I installed TG Pro and my fan issue is coming from the HDD fan. I was wrong about which iMac I have, its a late 2009. Searching for known issues, hasn't surfaced anything just yet.
by
Forgot to mention, the existing HDD is original.
by
Show 1 more comment
Add a comment
1 Answer
Most Helpful Answer
@jvemo - Jon We need to start over here as this system is different than the 2011 model!
So lets start with the systems SATA ports in this series they are SATA II (3.0 Gb/s) so the drives you use must support this slower I/O speed.
Here is the IFIXIT guide to replace the HD: iMac Intel 21.5" EMC 2308 Hard Drive Replacement. Similar to the 2011 model this system leverages the HD's internal thermal sensor. But unlike the 2011 model this model uses spare pins on a jumper block to gain access to the sensor. But! There are different connectors depending on the drive suppler Apple used for your given system (three different sensor cables!) In addition the header on the drive has more free pins for the cable so you could mix up the connection! This could explain why your fan is racing as the cable is not plugged into the correct pins! You can see in the guide on Step10 what I'm talking about here pictorially.
As far as adding a SSD, This model only has two SATA ports unlike the 2011 which has three. So you'll need to rethink things a bit as you'll need to give up your optical drive for the SSD. Here's the IFIXIT guide: Installing iMac Intel 21.5" EMC 2308 Dual Drive.
So your options are either do a dual drive as described above or make the jump to a 3.5" hybrid SSHD drive replacing your current HD. Which I think is the better direction.
Here is what you'll need:
iMac Intel 21.5" EMC 2308 Hard Drive Image
Guide
Difficulty:
Moderate
40 minutes - 1 hour
iMac Intel 21.5" EMC 2308 Dual Drive Image
Guide
Difficulty:
Moderate
30 minutes - 2 hours
Score 1
1 Comment:
@jvemo - I was still writing when you replied so take a read now.
by
Add a comment
Add your answer
Jon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 141
