Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Front camera not working after screen replacement
Hello,
I recently changed the screen of my iphone 6 (4.7") and the front camera was not working. When I opened the phone to check if the cable is connected it was. So I tested the camera while the screen was out of the shell body (all the cables were still connected) and the front camera was working just fine. I thought that I had a bad connection and put the screen back on. The camera stopped working again. I did this a few times and the same thing happens.
I have no idea what I am doing wrong, please help me!
Thanks
Score 7
1 Comment
On a 6s if the front camera isn't working and it is operating extremely hot it very likely could be a defective screen causing the issue. Had this to happen to me. I tried multiple screens from my regular supplier and I was getting the same issue so I tried a screen from a totally different supplier problem was then solved.
by
Add a comment
Chosen Solution
Hello,
There is likely one of two possible causes for what your describing: either a small tear in the camera flex cable or a grounding issue with new screen. With the screen & camera working while just connected with cables, the camera cable is not bent much, so a small tear may still make a connection. The camera cable is bent backwards with screen installed, so a small tear may separate. Use a magnifying glass to closely inspect the camera cable.
To test for a grounding issue with new screen, test the camera on the "original" cracked screen to see if it works when installed.
Score 7
Add a comment
I replaced my iPhone 7 Plus screen and now my home button, front camera, and sound doesn’t work why is this
Score 1
5 Comments:
Did you apply any heat around the edge of screen during removal, to loosen the adhesive? Did you disconnect the battery before removing or installing the screen?
by
I have the exact same issue, and I didnt apply heat to the edges and I did disconnect the battery before replacement. I tried a brand new camera and nothing. Camera doesnt work and i dont hear anything
by
Magdiel...I mentioned the heat around edge of screen during removal, because it keeps the screen from flexing so much during removal. The Home button can be damaged if the screen is flexed to much. Here's what I suggest to both of you:
1. Make sure that the connector on home button is properly seated to connector on screen, it can be a little difficult to connect. If it is...I suggest you remove home button and camera cable and temporarily put them on old screen, attach to phone and test them. If the home button, camera and sound works properly, then the new screen is bad. The screen has the home button cable built into it that connects to the phone, and could be bad. If home button is good but camera is bad...then you have a issue with the camera cable where it connects to phone.
by
2. The front camera connector on the phone side, also has sound connections. Check the area around the connector to see if any tiny components are missing, they may have been knocked off when the cable was first removed.
This will help isolate where the problems are.
by
Sorry, on the front camera...the first thing to check is to see if the cable has been torn anywhere. You must look closely, because even a slight, tiny tear can cause it to not work properly.
by
Add a comment
After performing the iphone 6s screen replacement, it is very likely to mess up the camera because of the new screen you put on. Try changing different screen and the camera itself which should fix the issue. Still not working then try resetting the phone or just try updating the ios on your iphone
Score 1
1 Comment:
iPhone 6 + front cam stopped working after getting screen replacement, restarted and worked again! Tysm @xpressphonefix !!
by
Add a comment
Are you certian that the camera stops working, or is the lense blocked just making everything black on the screen? You might simply have it positioned it in your phone wrong and thats causing it to not get a clear view out of the front of the screen causing the problem you are experiencing. Did your new screen come with those two little plastic brackets for the front facing camera and ambiant light sensor? If not you need to chip them off you old screen and superglue them onto your new one. Just take a pair of tweezers to handle the bracket, put a drop of superglue on a piece of cardboard or something disposable, and lightly dip the bracket into the glue on the side you are gluing down, then quickly get it on your new screen.
1 Comment:
Thanks for the reply.
https://youtu.be/6kHpGKY0XFg
Here I recorded a short video of the problem
All the cables look good.
by
Add a comment
Recently I change my IPhone 6s LCD screen and it’s not really responsive and when I play games and typing always glitch. And after all the front camera not function. Please help I have screen LCD screen warranty but I don’t want buy new front camera.
Add a comment
I have this issue on my iPhone 7 Plus. I changed the screen and the home button works fine. The front camera and ear speaker didn’t work. I changed the front camera piece with a new one. The ear speaker works, but front camera does not. I have no idea what the problem is. Help :(
Also, I changed the screen for a friend. Same issue happened. Ear speaker work, but camera does not. There is no way this could happen to me twice, I mean, I have no idea.
I did apply heat to easily remove and avoid tearing up the front ribbon cables. From reading this, I get that might have caused a problem. What do you guys suggest?
I got a new front camera part coming in as a replacement for the iPhone 7 Plus. I have to see wat happens.
3 Comments:
I recommend you do the following to isolate issue: temp connect home button and front camera to "original" screen and test. If camera works, you have a problem with new screen. If camera does not work, you have a problem with camera cable.
by
Also, if it points to new screen issue...it could possibly be the iOS. Apple is known for blocking out after-market hardware.
by
Pins get knocked off due to a short or just from impact etc. You will need someone with a microscope and a micro soldering service. The pins need to be resoldered. 100% the issue if new screen didn't fix it.
by
Add a comment
Add your answer
Teodor Todorov will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 38
All Time: 98,010
