I can't get it to access my WD My Book?
There was an unintended SHUT-DOWN and since that I've check the DISK UTILITY and I get this info.
FIRST HARD DRIVE
Verifying volume “Macintosh HD”
Checking HFS Plus volume.
Checking Extents Overflow file.
Checking Catalog file.
Illegal name
Illegal name
Checking multi-linked files.
Checking Catalog hierarchy.
Checking Extended Attributes file.
Checking volume bitmap.
Checking volume information.
The volume Macintosh HD needs to be repaired.
Error: The underlying task reported failure on exit
1 HFS volume checked
Volume needs repair
SECOND HARD DRIVE
Illegal name
Illegal name
g Catalog hierarchy.",0)
ed.",1)
Macintosh HD
Volume needs repair
WHAT CAN I POSSIBLY DO TO FIX IT?
Armando.
Comments:
This sounds like +S more than Disk Utility, are you sure you haven't got the two mixed up?
by
Disk utility gives these messages too, if you read the console thing it displays.
by
Ah, the log, I see now
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi! If you could please provide some more info -- is your laptop not booting up to its internal hard drive, or is it just not seeing your external hard drive? Have you tried using Disk Utility repair function? If your internal drive is not bootable, have you tried booting from the restore media and reinstalling the OS (which will not affect your files, etc., as long as you don't choose to do a clean install)?
Thanks
Score 1
Comments:
The laptop boots up just fine, and the repair function is not able to do it's job. I am interested in this other option you mention "restore media and reinstalling the OS" have you done this in the past and how do I go about it?
by
Add a comment
Well, what you need to do is boot from your install disk, open Disk Utility, and repair your drive.
Or boot into single user mode and type fsck -fy until your drive is completely repaired.
Comments:
It will not repair it, I did execute this process to no avail.
by
Hello Machead, I will consider this option as the last one; but ultimately I think it's going to be the only option I fear.
by
Then I'd go with a backup and replacement (or you could try reformatting), but it sounds fatal.
by
Add a comment
If you have access to another computer you can backup the data on the drives.
Your HD Master Directory is severely hosed, so much so that DiskUtility or FSCK can't repair it.... TechToolPro©, DriveGenius© or DiskWarrior© may be able to rebuild the directory (but after a rebuild I would copy all essential files, and reformat, reinstall OS)
Good Luck,
N.
Add a comment
Add your answer
Armando Escobar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,478
