Black screen or unresponsive touch
So i change the front panel of my Iphone 6s. But the touch diden't work and when i change back to my old screen now suddenly the screen is black (but the phone works since it's responding to the charger or vibrates when use the silent button.).
Does enyone know what the problem might be? did i damage some cords or something? I change it back and forth a few times and i get the exact same problems all the time
Did you disconnect the battery when removing the screen flex cables?? Try shining a flashlight or bright light onto the screen and see if you can see a faint image, if you can the backlight IC or associated resistors may have blown. However it is possible that the LCD ribbon cable is not making proper contact, check for any bent pins or debris in the logic board socket, try cleaning it with a toothbrush and isopropyl liquid.
by rayeasom
