Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
How to format replaced SSD in Mac Mini dual drive server
I successfully replaced the failed drive in my dual drive Mac Mini Server with a 960 GB Toshiba SSD - thank you iFixIt! However, the failed drive was the original boot drive and I am getting an error message when I try to log in to the server to format the new hard drive (which I planned to do via Time Capsule or Super Duper).
I am able to access files and the second hard drive is functioning ok as the server but I am not getting use of the new hard drive that I can then duplicate on the second hard drive for backup purposes.
Any ideas???
Add a comment
1 Answer
Chosen Solution
The easiest way here is to create a USB thumb drive installer. Follow this guide: How to create a bootable macOS Sierra installer drive
As much as you want the very latest MacOS I caution you not to! High Sierra alters the GUID/Mac OS Extended (Journaled) volume to APFS when it sees a SSD.
The issue here is the fact your system is SATA based SSD not a PCIe based SSD so it messes up the drive as the thinks it has the deeper number queues a PCIe has when in fact it doesn't! This makes coping & saving files within finder very slow!
OK so we'll stick with Sierra for now until Apple comes up with an update to address the queuing issue for High Sierra.
Now with the thumb drive boot up holding the Tab key to gain access to the boot manager, select the USB thumb drive and then run Disk Utility to setup the GUID/Mac OS Extended (Journaled) volume. Once don run the installer (just make sure you've selected the correct drive) That should do it!
Score 2
1 Comment:
As this is a replacement of the boot drive the hidden recovery partition is not present as it was part of now removed drive so the only other means is using internet recovery which is very slow in most cases.
by
Add a comment
Add your answer
whitney1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,169
