Guides and repair information for coffee and espresso makers from Jura Elektroapparate AG, a Swiss developer and distributor of home appliances.
How do I replace the seals in the Thermoblock?
How do I replace the seals in the Jura Avant-garde S8 Thermoblock? The halves need to be separated.
Add a comment
1 Answer
Chosen Solution
Look here - but you need to know some german words, or just use Google translate. The right guide is called "Revision des Thermoblocks"
https://www.juraprofi.de/Service-Anleitu...
Score 2
2 Comments:
This is wonderful! On page two of the guide, a tool that looks like a Nut Driver is used for the center bolts. My Thermoblock looks like it uses hex-head bolts and I am not sure I can find a thin Nut Driver to fit in the hex-shaped recessed hole. I will search.
by
The two bolts should be normal ones of 7 mm. The outer screws should be a Torx ( or Allen, don't remember?)
by
Add a comment
Add your answer
Lisa W will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 208
