Loud Speaker Not working
Hello
Was hoping you could help me out with a Loud speaker issue i'm experiencing.
The phone was purchased with the intent on replacing the loud speaker.
First impressions were to clean the ports for dust, however no results.
Upon opening i noticed the Red moisture tab which has made me worried. Phone works perfectly and was bought under the conditions it works fine and just needs a new Speaker so hoping theirs no serious moisture damage. Once again everything else works perfectly just the loud speaker.
As i was removing the screws by the charging port i noticed 2 screws missing which are supposed to hold the speaker down?
- one which holds the speaker to the frame towards the bottom and is the last screw to remove when replacing. Just by the charging port.
-Second missing screw was one closest to the bottom holding the metal wifi plate which has 3 screws.
Replaced the speaker with a new one and still no results. Could the missing screws be causing the issue?
Also as i was removing the 2.7mm screw on the taptic cable engine bracket near the port i accidentally used to much pressure and lost the thread on the screw so was unable to remove it, Not sure what to do about that now. Will have to be taken to repair shop with the right tool by the looks.
So had to somehow maneuver the speaker out pulling beneath the wifi bracket.. Could damage have been caused to the new speaker when pushing it in place as it was pretty tight and my finger managed to touch it few times..
Any advice on what could be causing the loud speaker not to work?
Hopefully no board damage as everything else works perfectly from headphones etc
Thanks for your help in advance
3 Comments
Missing screws from speaker are the 1.7mm screw and 2.6mm screw. Hope that helps.
Will reset or restoring the phone help with the speaker at all
by Gizmo
3rd screw missing 2.7mm from lower right of the speaker. So only 3 screws holding speakers. 3 closest to the bottom are missing
by Gizmo
re fitted the speaker, checked contacts, pins etc carefully however still not working.
Will try a new speaker and fit screws this time. Will update results for future reference, in case anyone decides to follow this
by Gizmo
