Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
iPhone 6S - Volume down button
Bought the phone that apparently had a problem with the volume buttons. Opened it and the water indicator from the logic board was red, although the one near the sim tray was white, so I assume partial water damage. I took it apart and washed the entire logic board with 99% isopropyl and installed a new upper component flex cable to replace the buttons. the problem is that after all, only the volume down button does not work, just like with the old flex cable, I don't understand why. The volume down button works randomly for some time and then I have to keep clicking it for a few seconds until it works and then stops working after a few minutes. Have also tried switching the button covers and don't know what else to do to fix this. Would appreciate any help.
Update (12/15/2017)
Here's a picture of the connector itself, looks pretty good to me, no signs of corrosion that I can see.
Score 2
2 Comments
I tried cleaning it again with 99% isopropyl and a brush and it worked very good after I reassemble everything and then stopped working..
by
I follow exact same.. 99% isopropyl is not necessary use brush.. First you need to dissemble everything.. Then soak everything into 99% isopropyl.. Let it soak in about a day.. While waiting for it soaking.. Go to Online Shop and buy a new one.. The new phone works like charm..
by
Add a comment
Chosen Solution
Here is a picture of the FPC connector to the volume down (FL4712, DZ4712, to C4712) and Schematic
Score 4
2 Comments:
Can you please send a picture of the logic board showing where exactly that component is? Thanks
by
I added it to the pictures above :)
by
Add a comment
Try cleaning the connector better and seeing if any components are missing. I think there is an inductor between the connector and the CPU so if cleaning more won't fix it ask me and i can show you where the component is.
Score 3
4 Comments:
I've tried cleaning it a few more times but it doesn't work. What else should I do? Thanks
by
@gigabit87898 and RDC4, I didn't mean to step on the answer but had ZXW open for another person and added the pics below for you ...Hope it helps
by
Nothing attached @gigabit87898
by
look at the answer above
by
Add a comment
Hi if someone can help
Plus and minus volume buttons not working. Silence switched and power button is working. Changed the ribbon cable but same symptoms. iPhone 6s 32gb?
Thanks
Score 2
Add a comment
I have cleaned everything I could and replaced the cable with a new one and the problem returned after some time. Don't know what else to do. The weird thing is that is just the volume down button that is not working.
Score 2
Add a comment
actually my mother bord is broken and volume buttons not working can you please send my the main print of volume buttons
Score 1
Add a comment
how to iphone 6s voliom up dawn sort problem solution
Add a comment
Add your answer
kraki will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 47
All Time: 8,672
