The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 Questions View all
Mac Pro crashing, then reboots
I have a Mac Pro that i Just installed a New Motherboard since it was causing Video to have line in it. But now it works fine then randomly will Crash. It will boot all the way off then reboot with a screen that says your computer has cause a error. Black square box. Then it boots and I got why it crash details but Dont know how to read or understand them. Can someone Help please thanks.
Anonymous UUID: A32B7C05-8CAE-7371-7F65-7523B7C5D582
Fri Nov 17 16:30:52 2017
  • Panic Report ***
panic(cpu 0 caller 0xffffff801afce5fa): Kernel trap at 0xffffff801afb5cf5, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0x0000000000000000, CR3: 0x000000019a021000, CR4: 0x0000000000002660
RAX: 0x0000000000000001, RBX: 0xffffff802c27f000, RCX: 0x0000000000000000, RDX: 0x0000000000000060
RSP: 0xffffff90d19dac80, RBP: 0xffffff90d19dad00, RSI: 0x000000012a2f0000, RDI: 0xffffff80249a3500
R8: 0x0000000000000001, R9: 0x0000000000000060, R10: 0xffffff801f722101, R11: 0xffffffffffffff9f
R12: 0x00000001a8005000, R13: 0xffffff80249a3500, R14: 0xffffff80297da8a0, R15: 0x0000000000000060
RFL: 0x0000000000010206, RIP: 0xffffff801afb5cf5, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000000, Error code: 0x0000000000000000, Fault CPU: 0x0, PL: 1
Backtrace (CPU 0), Frame : Return Address
0xffffff90d19da910 : 0xffffff801aedab12
0xffffff90d19da990 : 0xffffff801afce5fa
0xffffff90d19dab70 : 0xffffff801afec463
0xffffff90d19dab90 : 0xffffff801afb5cf5
0xffffff90d19dad00 : 0xffffff801af7a21c
0xffffff90d19db090 : 0xffffff801b3d8e53
0xffffff90d19db0d0 : 0xffffff801b0eee28
0xffffff90d19db270 : 0xffffff801b0e99f2
0xffffff90d19db510 : 0xffffff801b31168c
0xffffff90d19db5a0 : 0xffffff801b33c86f
0xffffff90d19db660 : 0xffffff801b129d04
0xffffff90d19db6d0 : 0xffffff7f9cd645fd
0xffffff90d19db730 : 0xffffff7f9cd6423b
0xffffff90d19db800 : 0xffffff801b14110b
0xffffff90d19db830 : 0xffffff801b332e4e
0xffffff90d19db890 : 0xffffff801b126d07
0xffffff90d19db8f0 : 0xffffff801b11a5ff
0xffffff90d19db9a0 : 0xffffff801b1061b8
0xffffff90d19dbbe0 : 0xffffff801b106cd0
0xffffff90d19dbf60 : 0xffffff801b4286a1
0xffffff90d19dbfb0 : 0xffffff801afecc66
Full panic report: Panic Report
1 Comment
Are you able to boot up on an external bootable drive? I would start there.
by
Add a comment
1 Answer
Most Helpful Answer
These symptoms indicate a failing power supply. The restarts just keep getting more frequent until you replace it. Done it many times on this 1st generation.
Mac Pro First Generation Power Supply Unit Replacement
Score 3
Add a comment
Add your answer
integratype9001 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 7
All Time: 71
