MacBook Pro early 2011 logic board does not get enogh power
Dear all,
I have an early 2011 macbook pro.
If I plug in the charger it says that the battery is not charging, but it also drains power from the battery.
If I disconnect the battery, try to make it work with only the charger, in the cases it actually boots, the computer is really slow and turns off after a few minutes. If the battery still have some juice the computer behaves normally.
I also bought a new battery from ifixit and it has the same behaviour.
I tried the smc reset, different charges and to disconnect both the charger and the battery and then press the power button for 10 seconds, but nothing works.
On a side note, it happened that after the computer continued to be plugged to the charger for a few hours while being turned off, it started to charge up the battery slowly, but it did not show this behaviour in the last 72 hours. Clearly it stopped charging up if I turned the computer on.
I think it is the logic board that works but it does get enough power.
So do you have any idea?
2 Comments
I suspect your logic board has an issue here. Did you have a liquid spill of some sort? Or sit your system down in a puddle?
Your symptoms imply you have two distinct problems:
You'll need to open the system and make a good inspection look for stains and corrosion. Take some clear snaps and post them here for us to see.
As far as the slow system you likely need to replace the HD SATA cable as that is a common issue.
by Dan
Hi Dan,
The computer did not suffer any liquid spill in the last few years. Last time it happened it was the 2015 I had to change the keyboard and the trackpad.
The slow behaviour is probably due to the insufficient supply of power to the logic board and the cpu when the the battery is disconnected or without charge. It should not be the hdd cable because it was changed this summer.
by Vittorio Latorre
