Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
I'm having an iMac backlight problem
My mid 2011 Imac is having backlight problems.
When I turn it on and shine a flashlight on the screen I get a faint picture, I tested every pin on both the power supply and inverter board and am getting 12 volts everywhere. I tried hooking it up to my television today. Nothing. I'm completely stumped.anyone have any ideas? The hard drive recently went and I replaced it. Everything else seems to be working fine except the backlight.
2 Comments
Have you ever has this TV hooked up to a computer before.
by
No not until this afternoon.
by
Add a comment
1 Answer
Chosen Solution
@thechain this "shine a flashlight on the screen I get a faint picture" sounds like a LED driver board issue. I'd consider this "hooking it up to my television today. Nothing. " a red herring for now. Check your LED driver board by taking a good look at it and see if you find any components that appear damaged etc. Use this guide iMac Intel 21.5" EMC 2428 LED Driver Board Replacement to work on it. You can of course also post some images of your boards with your question so that we can see what you see in case you need more help with that. Use this guide Adding images to an existing question for that. Bottom line for me is to replace the LED driver board and see if that brings your iMac back to light.
iMac Intel 21.5" EMC 2428 LED Driver Board Image
Guide
Difficulty:
Moderate
20 minutes - 1 hour
iFixit Image
Guide
Difficulty:
Very easy
2 - 5 minutes
Score 2
Add a comment
Add your answer
James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 112
