Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
iPhone 6 Plus Digitizer issues
I run a side business repairing iPhones doing anything that don't require micro soldering. My skill level is pretty extensive as to understanding of the board and etc. just don't have the equipment to properly repair micro soldering jobs.
I've came across what I accessed as a simple job.
Client stated that screen was busted just needed a replacement.
I did the repair and a few hours later client states that phone is being unresponsive to touch at times.
I checked the phone too make sure the flex cables wasn't bent or tore. Also disconnected the cables and reconnected to under proper seating of the flex cables.
Phone works fine for awhile but then starts to act up again by not being able to touch anything after a few power on and offs it became responsive again but shortly after it yet again acts up.
I push at the top right hand corner of the screen and it makes it work again sometimes. So I got another screen and tried it. Same problem. Another screen to be %#*@ sure it wasn't the screen. Again it acts up.
Tried 3 screens and problem was present in all 3 screens, mind you they was from the same supplier what's the chances of all 3 screens doing the same thing? I use cellphoneage.com for my screens and of all my time doing tons of repairs I've never had this problem. I've cleaned the digitizer connector with alachol and a small brush. Nothing helped.
I attempted to put a piece of paper on top of the connector before I put the plate on to insure a solid connection and it actually helped to some extent. Although it wasn't a 100% fix because it would still sometimes act up.
I inspected the digitizer connector on the board to make sure there was no damage there and all the connectors are there and no damage seen.
I'm thinking maybe it need a new connector on the board to the digitizer. despite the good shape connector, also in not sure if this problem was preset before my repair.
Any ideas?
2 Comments
Also forgot to add that when I lift the screen up like I'm taking it out, it will work.
by
If it is happening to all 3 screens, it's definitely a board related issue. My guess is when you put the shields back on and close, you are putting just enough pressure on the board to flex it ever so slightly. Meson and Cumulus sit on the opposite side of the Flex connections.
by
Add a comment
Chosen Solution
The phone has "Touch Disease". Classic symptoms for the Iphone 6 Plus. The Meson Ic will need removed, run a jumper on the M1 Pad and put back on... About a $50 to $60 fix and it will be perfect.
Score 1
3 Comments:
Are you charging 60$ for Touch Disease?
by
@refectio , Sorry... Wasn't trying to advertise pricing. But yes, I charge $59.95 for Meson and M1. I add $20 additional if I have to pull Cumulus...not including parts
by
Hi! I just wonder if this forum is still alive. So. I have a 6 Plus. The digitizer is cracked, bought a new one and it doesn't work. The old one which is cracked also doesn't work at all. I am almost sure the problem is in the logic board not in the digitizer. The LCD works just perfectly, but the digitizer refuses to react anyhow to touch. I read many forums, I watched many videos on YouTube. Such fixes like nano sim, do not work for me. Rewa Technology has a video replacing the Meson Ic I suppose. Before unsoldering and resoldering the component, I just wonder, shall we have any voltage on the flex connector of the digitizer? How can I figure out that the problem is in the Meson IC and not in a "poor" capacitor somewhere on the logic board? And what do you mean by making a jumper on M1? Sorry, I am rather new in iPhone reparation. Would highly appreciate any help. Thanks!
by
Add a comment
Most Helpful Answer
Try to put an test screen without anything on it, no proximity or shield,
Maybey the the shield touches some component that make the phone not work properly
Score 1
Add a comment
I had this problem, in my case it was a manufacturing defect from my supplier turned out when screen was pushed down onto phone screen would not work. It was flex cables were slightly shorter. I had phone in my cupboard for about a month then tried a screen from my new supplier and it worked a treat.
Score 1
Add a comment
Add your answer
Frost tech repairs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 5,308
