Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Replaced the rear Camera and Phone does not recognize it same w home b
I followed all the instructions on the rear camera replace and once phone was put back on, the camera does not work and the home button does not work....never had a problem with the home button...
it seems like a software issue?.....do i need to do a hard start?...or a restore?..
2 Comments
Did you keep track of the screws in the shield covering the flex cables and get each one put back in it's own place? Have you also looked carefully around the connectors for the camera and home button on the logic board for any components that may have been damaged or missing?
Does your flashlight work and your front camera?
by
Michael and All...thank you for your responses, our issue was traced to a wrong camera ordered....we just ordered the correct part and it is soon to arrive....at that point and once we open this phone again we will also look at all the connections to the logic board as most likely the HB got disconnected when the phone was last worked on.....Thank you!!
by
Add a comment
1 Answer
Chosen Solution
You can a always do a force restart. But software probably isn't your issue. If all you did was remove the display then try power cycling. That or I would guess you've damaged the home button cable. This is not a common issue for this phone
How to Force Restart an iPhone 6 Plus
iPhone 6 Plus Home Button Link Cable
iPhone 6 Plus Home Button Link Cable Image
Product
$14.99
Score 2
Add a comment
Add your answer
Gus Maragliano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 34
