Samsung smartphone released in January 2016. Model SM-J320
48 Questions View all
Phone touch screen not responding Samsung J3 [J320n]
after doing a hard reset the touch screen is still unresponsive. also when it was dropped initially about 10 hours ago the left side of the screen had a tiny crack. any ideas on what could be broken? Screen or motherboard?
any help?
Add a comment
Chosen Solution
Jack Nicolsen you cannot make the determination without working on it. The number one give away on here is this "dropped initially about 10 hours ago" and " the left side of the screen had a tiny crack" You have a failed digitizer. Replacing that will resolve your issue. This video should help you with that. Don't start soldering on the board until you have properly checked everything else.
Score 1
Add a comment
I just cleaned the digitizer port contacts with contact cleaner and it worked.
Add a comment
Add your answer
Jack Nicolsen will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 8
Past 30 Days: 11
All Time: 7,889
