Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
5s dying randomly before & after battery replacement, hours to turn on
I replaced my iphone 5s battery myself because my phone was randomly dying. Each time it died it would have to be plugged in for several hours before actually begining to charge. This was an issue with multiple chargers/outlets. Pretty sure it only turns on and begins charging with a system reset (again only after multiple attempts and a few hours of being plugged in). After replacing the battery, I'm experiencing the same problem. What's up?
1 Comment
could possibly be the charging port
by
Add a comment
1 Answer
Most Helpful Answer
Treat any repair like surgery and do as the surgeons do: look for a noninvasive way to resolve the problem.
  1. Double check the charging cables and wall adapters you are usinge are MFi Certified. This standard of certification is produced by Apple for accessory makers and certifies that your accessories will work as designed without damaging the device. If you don't have the original cases for the accessories you can use the purchase price to tell. If you bought the accessory for less than $3, chances are you don't have a certified item. It lacks the chip (which costs $3) necessary.
  2. Shine a light into your charging port and look for signs of lint or dirt/dust blocking the charge. You can take a toothpick, SIM card eject tool, or tweezers to scrape out the gunk.
  3. Check the SIM Card Tray area for a tripped Water Damage Indicator. This can be found by removing the tray and looking up (towards the screen) from the bottom for a little circular sticker. White = No water. Pink = Water. If there's been water damage you may be entering a "rabbit hole" of issues as is common with water damage. Best to get it professionally cleaned.
  4. If you have to open the device back up start with the areas you didn't touch: The Charging Port. This is a simple fix, but can be time intensive as you have to remove a fair amount of screws and a speaker, along with adhesive.
  5. If nothing else works try another battery. You never know, maybe you got a defective one.
Score 2
1 Comment:
Time to change your avatar. How's the new job going? You've been missed.
by
Add a comment
Add your answer
Robin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 94
