Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
Replacing my PCI-e SSD.
Hello,
Im running out of space, and i'm looking into replacing my SSD for a higher capacity, is that possible? If it is what Brands and models are compatible.
Current SSD is APPLE SSD SM0512F 512GB.
Score 1
Add a comment
Chosen Solution
The idea here is to setup a dual drive system (SSD & HD). The SSD will have your OS and apps and the second drive would be for your files (music, pics & vids). You'll likely want to compose vids & music off of the SSD then save your work over to the HD.
This way you're maxing your dollar as HD's (even a SSHD) is cheaper than an SSD.
Yes, you still could put in a SSD but you won't really leverage it as you'll want to use the still faster SSD as your boot drive (the PCIe blade SSD).
If you really want the SSD you'll need an adapter frame like this one: OWC 2.5" to 3.5" Drive Adapter Bracket and you'll still need the in-line thermal sensor i listed above.
Score 1
Add a comment
Most Helpful Answer
Why not just add a hard drive for storage?
iMac Intel 27" EMC 2639 Hard Drive Replacement
Score 3
3 Comments:
I agree a much better solution!
by
Would an SSD work instead?
by
Almost forgot! You'll need this as well with your new drive: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later as only the Apple drives have the sensor built-in.
by
Add a comment
Add your answer
Ali Alduwailah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 252
