The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Rfmodule replacement for xbox slim
where do i get a replacement rf module?
Score -1
Add a comment
Most Helpful Answer
here is one http://www.dhgate.com/microsoft-xbox-360... 2.Use in any Xbox 360 console system. eBay has a few on as well http://compare.ebay.com/like/22073459560... looks like the rf module is the same in all 360 GoodLuck
Score 1
2 Comments:
will it work on slim?
by
The information that i have is that the modules work in ALL 360, so should not be an issue, but if you are not certain, ask the vendors.
by
Add a comment
The way it looked to me when I took my 360s apart is that the 360s RF board connector is thinner and longer than the original. I believe this is because the eject button is wired to the RF board (a need for more pins) unlike the original that had a physical button. Also the form is different for the 360s RF board due to the rotation of the USB ports. All that being said this is what you need http://www.ebay.com/itm/XBOX-360-SLIM-Ri...
Score 1
Add a comment
You should definitely check on ebay. I purchased a used RF board for my slim xbox and it works perfectly. $5.99
Add a comment
Add your answer
denver will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 1,904
