Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4632 Questions View all
New battery isn't charging!
I've looked through old forums and all they said was to reset to PRM or SMC. I've tried both several times with no luck. When I first got the new battery, it wasn't charging, but after fiddling with the cable, it charged up to 23%. However, I unknowingly unplugged it and it went down to 8%. Now, it's slowly decreasing and it's at 5% now.
And the magsafe won't turn green. I suspect it's a problem with that, but I don't want to spend money on a new one (because this is already a new one)
1 Comment:
Which cable did you fiddle with? What was the issue with the old battery? Exactly which MBP do you have and what is the battery number?
by
Add a comment
1 Answer
I had a similar problem with my MacBook Air once. It would not charge with any MagSafe charging cable.
To fix this, I had to replace the I/O board on the MBA. I would recommend the same fix for your Mac.
MacBook Pro Unibody DC-in Board (part)
Guides for different models can be found by scrolling down to the 'Replacement Guides' section in the linked page above^
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Image
Product
$9.99
Add a comment
Add your answer
Gahye S. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 193
