The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
104 Questions View all
摔了之后无法连接到Wifi怎么办?
摔了之后,外壳和屏幕并没有受到太大伤害,但是从此:
  • 无法连接到Wifi;
  • 无法使用运营商的网络语音通话;
只能通过移动网络上网,怎么办?
补充的情况是:
  • 摔之前是Android 7.x,恢复原厂n次无效;
  • 用移动网络流量硬生生升级到Android 8.0,问题依旧;
  • Wifi开启时,能找到预设的热点,状态就是重复连接然后重复不成功;
求大神指点,谢谢!
English Version
After falling, the shell and the screen were not hurt too much, but from then on:
  • Can not connect to Wifi;
  • Can not use the China Unicom network voice calls;
Can only be through the mobile network, how to do?
The supplement is:
  • Before the fall is Android 7.x, restore the original n times invalid;
  • With mobile network traffic abrupt upgrade to Android 8.0, the problem remains the same;
  • Wifi open, you can find the default hot spots, the state is repeated and then repeat the unsuccessful;
Seek the guidance of the great guy. Thanks!
Score 1
Add a comment
Most Helpful Answer
这是Pixel主板的设计缺陷,我跟深圳的维修商家交流过。对方说Pixel的主板设计得太脆,经不起摔,且内部芯片和线路存在缺陷,Wifi断线、反向充电(插充电器不充电,只能关机充)问题很多。我也因为2.4G Wifi连不上去专门修过,花了200块钱,最终确实解决了问题。网上什么重置网络设置,安全模式,拔SIM卡等等方法都没用的,别浪费时间试了。
For English friends if you need:
This was a design flaw comes together with 1st gen Pixel. I communicated with repair engineer at Shenzhen, and he said Pixel’s motherboard is too fragile to tolerate falling and there are flaws in chips. Wifi connection failure, reversed charging (cannot charge while plug in, must shut down before charging) issue has affected many people. I was also looking for reparing of 2.4G Wifi connection issue. It cost me 200 RMB and actually solved. Those tips and steps on the Internet such as reset network settings, safe mode, remove SIM card, etc., will be uselesss. Please don’t waste your time on trying those meaningless things.
Score 2
Add a comment
肯定是你的主板蓝牙模块摔坏了,如果过保请找一家维修店维修。换芯片也不高。
Add a comment
Add your answer
Dake will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 1,046
