Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
LCD won't display iMac
After switching my imac hard drive and putting back together all worked well apart from the fact I had forgotten to plug in the temp sensor for the hard drive in so the fans were spinning loud
So I took it apart and re assembled the imac however there was no display but a chime. Upon further inspection I found I had damaged the display connector on the logic board and the LVDS cable.
So I replaced the LVDS cable however no luck so I assumed the damage to the logic board was the problem. I then bought a new logic board from a seller on ebay as is was cheaper then getting the connector resoldered at a repair shop.
However after switching the cpu and gpu into the new board the problem remained: no display but a chime.
I then realised the problem may be the gpu as is common on these models of imac. So I then ordered a mini dp to hdmi cable to see if it would display on my TV (of which it did success fully)
I am now very stuck as I'm not sure what the fualt is, the display was working fine before without a dead pixel in sight. Before suggestions of reseting SMC ect I have already tried this and I have further checked if the backlight is the issue but there is no display at all
What should I do now?
Add a comment
1 Answer
Most Helpful Answer
Check your connections to the LED driver board. Tell us what the diagnostic LEDs are telling you.
iMac Intel 21.5" EMC 2389 LED Driver Board Replacement
Score 2
1 Comment:
3 of the diagnostic LEDs light up
And have checked all of the connections pretty much everywhere many times
by
Add a comment
Add your answer
Bramley Greenfield will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 110
