Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Why Does my screen blink intermittently? APPLE CANT FIGURE IT OUT!
Why Does my screen blink intermittently? APPLE CANT FIGURE IT OUT!!
I've had this problem come up recently. This was a problematic MBP mid 2012
The Logic board was replaced in warranty as one of the memory slots doesn't work so running single slot.
Symptoms:
  • Screen blinks to black and the ability to move the mouse in that instant is lost.
  • Screen blinks on battery and magsafe power
  • No change with movement of the LCD screen
Update (10/10/2017)
Here are two video clips. One of them shows how it blinks when I'm using it, and the other shows it blinking on the reboot page.
Score 1
4 Comments
If you connect it to a external monitor/tv does the computer work on the external monitor or does it do the same blinking?
by
apple tried to connect it using the thunderbolt and apparently my thunder bolt was not working?
by
Saw the video now. Seems like it is loosing backlight voltage. Should be an easy fix for a board repair shop.
by
Contact Apple Support
by
Add a comment
Chosen Solution
Apple can't figure it out because most of their "Techs" are completely clueless. More than likely, the displays LVDS connection on the logic board is making intermittent contact.
You can fix this with a Phillips screw driver. Open up the bottom following this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Lower Case Replacement. Having the system in front of you with the battery at the top and the fan at the bottom, Look in the lower left corner. You will see a gold/silver plug. Pull that out toward's you. Then plug it back in (keep it flush on the logic board).
That will probably solve the issue. Lets not get too in depth until we do this.
Score 4
19 Comments:
@tcrs_circuit Thank you for the prompt response.
I reconnected the the lcd power Cable as you suggested and the problem still persists.
It is currently unusable in this condition.
by
Is this a 13 inch model? Or a 15 or 17?
by
Wait a sec. You may have lucked out. This may be a case of broken solder joints on the U8900 chip. Really easy fix for someone with the correct equipment and skills.
by
@tcrs_circuit Bad mouthing Apple's finely trained techs is one of the first clues that you're a top rated and knowledgeable technician ;-)
by
@mayer Didn't know if that was appropriate or not on here.
by
Show 14 more comments
Add a comment
No, this is a hardware issue not software. OS or driver failure wouldn't react this way. Diagnostics have limits on what they can test. As you can't test your system via an external display as the port is bad I'm thinking you have a logic board issue Vs a screen here.
I would go back to Apple and focus the repair on the Thunderbolt port which should resolve both issues.
Score 1
Add a comment
  • Shut down computer.
  • Power off 2nd display.
  • Power on computer.
  • Wait for the boot to finish.
  • Power on 2nd display.
This works for me on a trash can mac pro late 2103
Add a comment
Add your answer
Carlos Adamez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,054
