Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Battery percentage constantly changing sometimes does not turn
HI guys,
As the topic says I have an iPhone 5s which acting weird. Battery percentage is fluctuating sometimes does not turn on or charge.
Now some background information. Originally I was trying to replace broken screen and before doing that I disconnected the battery connector. While doing that I think I have shorted something as I was using metal tweezers (I know not very smart) and saw small spark. My assumption is that I shorted battery connector pin 5 (which is according to schematics is PP_BATT_VCC_CONN) to ground. It could also be other battery pin 4 (AP_BI_BATTERY_SWI_CONN).
So far I have measured all the caps and one filter near the battery connector and they are fine.
My guess then is that I damaged something in battery internals or is it something more serious?
I appreciate if you could help me with this issue.
Add a comment
1 Answer
Chosen Solution
It sounds like the gas gauge line (BATTERY_SWI) was damaged. If you already checked the filter (FL11) then you may have damaged the circuit in the battery. I would try a new battery first to see if that solves the problem before attempting any repairs on the logic board.
Score 1
Add a comment
Add your answer
Karolis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 155
