NAND CHIP Serial Number
hi
how to get Nand SN and other infos like country code, wifi Mac address if the iphone has problem in Nand & need to be replaced using Naviplus pro
hi
For the iPhone 6 I don't believe you need the Mac address. It is critical for the 6S and later.
As for the S/N and country and other info, and even Mac address, the Navipro will extract them from the NAND unless it is damaged beyond repair and beyond the ability of Navipro to read it.
One way to do it is pull the S/N by submitting the IMEI to a paying service.
The rest you can enter manually or copy over from a working NAND then just edit the S/N and color (if needed).
Any free way to get Nand S/N using IMEI..Thx
It costs about a $1 or $2 to request a GSX report.
355877060768944
In which website i can get that data
actualmente si le cambias la serie y lo formateas el sistema lo detectara y no podrĂ¡ activarse, hay que registrarlo en la BD de apple, alguien que tenga proveedor o venda series registradas
According to google translate this person says: "
now if you change the series and format it the system will detect it and can not be activated, it must be registered in the apple DB, someone who has a supplier or sell registered series"
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 3,093
