Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4632 Questions View all
After motherboard replacement, Battery not being detected.
Hey guys, I got a new motherboard put into my macbook pro. I had spilled water on my macbook and the battery stopped being recognized and the entire computer ran very slow. After researching some, everybody suggested new motherboard. So I installed the new motherboard and I am still having the same problem. The computer runs much faster now and works correctly, however the battery is still not being detected. I've tried multiple batteries as well as ran the Apple Diagnostic tool and no errors were found. Any ideas?
5 Comments:
Did you replace the DC-in as well? What exactly do you mean by "not being detected"? What color is the light on the DC-in? Does it turn amber when you connect a known-good battery?
by
It turns a solid green and no I have not replaced the DC in port.
by
Disconnect the battery level indicator and test again.
(Also please tell me you tried a different "known good" battery with the old before replacing the entire mother board? Not just after replacing the board).
And where are you located? You still have the damaged board?
by
Please tell us exactly which MBP you have.
by
Hello everyone. Sorry this project had to be set on the back burner. I have now replaced the MagSafe and the light is still green. The battery is still not detected. Ok we are new motherboard and new MagSafe connecter in and still no fix MacBook Pro 2011 13” still not reading that there is a battery installed.
by
Add a comment
1 Answer
hi, Once you have fully drained the battery, when you plug in the MacBook, MacBook Air, or MacBook Pro's power cord and start the computer up, you may see an X over the battery icon in the menu bar. If you see this, allow the battery up to five minutes to come out of its low power mode and begin accepting a charge again. If your battery still is not recognized by the computer—if it still has an X over the icon—after five minutes, you may want to reseat the battery on your MacBook or MacBook Pro (applicable only to models with removable batteries). If the battery still isn't recognized after reseating, try resetting the SMC.
good luck
1 Comment:
This unfortunately did not fix the issue. When resetting the the smc the MagSafe didn’t change any color either. Still solid green.
by
Add a comment
Add your answer
Micaiah Martin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 782
