Can anyone help me with replacing the plug for my headset?
I cut open then cable and I now have a Red, Green, Blue and Copper wrapped around a White wire.
I have my replacement plug and also need help to where I would solder them.
Add a comment
Chosen Solution
Hi @jeci ,
This is the wiring for a Turtle beach Ear Force PX22 so a reasonable assumption would be that it would be the same for a Turtle Beach Ear Force Z22
Starting from the "tip"
1. Green - tip
2. Red - ring 1
3. White - ring 2
4. Blue and copper twisted and soldered together - sleeve.
Score 4
Add a comment
I've never seen this combination of wires before. My advice would be to strip back the original plug and see how it wires up.
Normally white is ground/neutral (the copper part too) and red is the right channel.
Hope this helps!
Score 1
2 Comments:
Unfortunately I lost the original plug. The cable is for Turtle Beach Z22 Headphones and am curious to what the blue is for.
by
@jeci, I believe that green and blue wires are for Mic and left channel, but I'm not sure which goes to which. You should try around different stuff.
by
Add a comment
Hi,
In Samsung Galaxy compatible earphone, the pinouts are as follows:
1= Head = Left = Green
2= Ring 1 = Right = Blue
3= Ring 2 = Ground = Copper = Gold = Common
4= Base = Mic = Red
So:
3,4 = pause switch
1,3 = Left earphone (35-50 Ohms)
2,3 = Right earphone (35-50 Ohms)
Add a comment
Add your answer
Jesse Garcia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,600
