Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Screen does not turn on at all (tried replacing charging port as well)
I had replaced my sister's battery recently as it was starting to lose its charge very quickly. However, in a month or so, she comes back with a broken phone that does not turn on or is recognizable to itunes either.
She told me she had used a portable fan that plugs into the bottom of the phone (a cheap chinese brand I think) which I speculated is what caused the damage to the phone. What do you guys think? Or, it's just coincidence and happened to died right after.
But anyways, so I thought it was the charging port that broke. So I replaced that, and still no luck. Also, tried hard resetting as well. If you guys could give any ideas on this, that'd be incredible!
Thanks,
Robert
Add a comment
Chosen Solution
You're probably right. Cheap peripherals can draw too much current or cause voltage spikes that damage the charging circuit (Tristar).
This will have to be repaired by a shop that does micro-soldering work.
Score 3
5 Comments:
Thank you for the response. How much do you think it would cost to repair that?
by
Dealing with a reputable micro-solderer will cost you about $100 - $150. Some may charge more and some less.
There are a few reputable micro-solderers who frequent this forum or you can search Google. You can check out my profile if you'd like, at the very least it will serve as a data point
by
@mayer @oldturkey03 not sure if this is okay...but answering a direct question. Let me know.
by
Robert Actually this is just the type of repair that Minho specializes in. @refectio You're fine with me, you didn't recommend yourself or post your web link (which is in your profile), right?
by
@refectio @mayer looks good to me as well.
by
Add a comment
Have you checked voltage on the battery? Maybe the new battery was junk and died already, especially if it was an ebay part. Use a multi meter on the outer pins of the battery connector. Report back what you find.
Score 1
1 Comment:
Good point !
by
Add a comment
check the FPC socket, it is connection trouble
Add a comment
Add your answer
robert7kim7 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 76
