Repair information and guides for MacBook Pro 15" Retina Display laptops from 2012 and continuing.
3614 Questions View all
Backlight Not Working and in Password Reset or Welcome/Language Select
I replaced the retina display on Mac Pro 15", mid 2015 after months (no battery charge).
Backlight is not working -- but I can see by shining a light through plastic apple behind screen that computer is on.
Using another monitor through HDMI cable, I get stuck in either the Password Reset -- which, when I attempt to reset tells me there is a server error (repeatedly).
Otherwise, I got to the startup prompting selection of language and agreement to terms.
Any ideas?
Add a comment
1 Answer
Might be worth checking you put the cable from the monitor to the MB in correctly, and you didn't accidentally unplug a WiFi antenna when you were routing around inside, that might be why you're getting a server error on the password reset. Does it work over Ethernet?
2 Comments:
Thank you, Jack.
I'm hesitant to move anything in the computer. I opened it again, and it all looks good. Also, once or twice I was able to get to my password prompt, but my password doesn't seem to be working -- which I'm thinking now is maybe because I started a reset request.
So the main problem is the backlight -- I think.
by
The parts all fit. My Pro is a mid-2015, though, and I see that iFixit has a mid-2015 screen.
Could that be the problem? (I don't even know whether this is stupid question.
But I really think I got all the parts connected correctly, after 2 hours working on the thing, very carefully.
by
Add a comment
Add your answer
Lou Schiano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 42
