Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
bluetooth does not work
Hello, I'm new here, I have a problem with the bluetooth of my iphone and it's that I do not appear, I leave a photo to see how they can help me
Score 1
1 Comment
thanx, i will try, and tell you
by
Add a comment
1 Answer
Chosen Solution
Hi Chris, you don't give us much to work with...
What's the history of the device and what happened just prior to this problem? If it came out of the blue and was working fine before then I would simply try to do a hard reset. Hold the Home Button and Power Button for 10 seconds and let the phone restart.
If the phone was dropped, damaged or repaired, then the problem is internal and hardware related but you'll have to give us more details.
EDIT
Well, at this point you'll have to open up the phone and take a look inside. This is what the Bluetooth antenna looks like. You can see it within the housing on Step 66 of the Rear Housing Replacement guide.
While there is no specific guide for changing this antenna, I would follow the Logic Board guide to remove all of the parts necessary to access it.
I can't guarantee that this will solve your problem. Otherwise, consider having a professional look at your phone to properly troubleshoot it.
Replace a torn or missing Wi-Fi and Bluetooth Antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi and Bluetooth service. Part #821-00128-A. Image
Product
iPhone 6 Plus Wi-Fi/Bluetooth Antenna
$22.99
iPhone 6 Plus Logic Board Image
Guide
iPhone 6 Plus Logic Board Replacement
Difficulty:
Moderate
40 minutes - 2 hours
iPhone 6 Plus Rear Case Image
Guide
iPhone 6 Plus Rear Case Replacement
Difficulty:
Difficult
1 - 3 hours
Score 1
1 Comment:
sorry, the cell did not fall, the wifi and the gps work fine, I already did a hard reset.
by
Add a comment
Add your answer
chris camejo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 158
