Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Questions View all
replaced iPhone 6s screen. Not very crisp or clear the screen..
Hi,
I have just replaced the iPhone 6s screen. And the replacement screen doesn't look clear and crisp at all. There are slight vertical lines going down the screen Slightly grey/ and black the lines about half a centimetre thick. Is this a faulty replacement?
Add a comment
1 Answer
Chosen Solution
From what you describe, it is most likely a damaged ribbon flex or connector issue. Verify there are no bent or damaged pins on the connectors, debris, etc... connect the LCD without putting it back together...and while holding it carefully so you do not disconnect the connector while powered on (Can cause backlight damage to connect or disconnect while powered on) see if it clears up.
Do you have the old screen to test with? If old screen works and new one doesn't, most likely a bad replacement part or damaged Flex or connector.
Score 2
2 Comments:
hI, just tried what you recommended. It looks like a bad replacement. thanks for answering
by
You are welcome, Best of luck! :)
by
Add a comment
Add your answer
julian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 84
