Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
MacBook turns of after few seconds during startup
Hi, My Macbook turns off after app. 10 secinds during startup.
I did a lot of google on this, and can see different suggestions but no clear answer.
If I hold a key on the keyboard, it sometimes will start, so I was able to do a backup.
After new installation of MacOS it has the same error, so it must be a hardware error.
I can see that a lot of suggestions point on the keyboard, and I could try to replace that, but I cant see a guide for this here.
Anyone with the same experience og a suggestion on what to do?
Thanks,
Henrik
2 Comments
Please give us a history on this machine.
by
What do you mean about history? Nothing special has happened to the machine. No liquid or other accidents. Just normal daily use.
by
Add a comment
1 Answer
Chosen Solution
You need to determine whether it's a keyboard issue or a board-related issue. Pull the keyboard cable and jump the laptop with the power-on pads on the board. If it stays on, you have a bad keyboard. If it still shuts off, you're likely dealing with a board issue.
The fact that "holding a key" allows it to stay on suggests you probably have a bad keyboard with a stuck key. Often in that case, holding in a key can temporarily counteract the effect of the stuck key.
Score 2
Add a comment
Add your answer
Henrik Follmann will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,178
