Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Flashing white screen after battery replacement
Replaced battery in iPhone 6. Plugged it in to power with original Apple cable/charger, and all I get is the white screen with black apple logo. Comes on for a few seconds, goes black, comes on again. Over and over again. Have tried holding power/home button, plugging in to computer (iTunes does not recognize), and reseating battery. Do I need another new battery?
Add a comment
Chosen Solution
iPhone is not properly recognising the battery.
Reseat / Replug the battery cable and try turning it on again.
If it still does the apple boot loop then you have a bad replacement battery.
Score 4
4 Comments:
Thanks, Ben! I didn't have the battery seated quite right, so reseating it worked.
by
Kthyne, Please remember to select the solution that worked for you so other members will know what worked :)
by
Hi Michael, I selected "Yes" yesterday about two hours before your comment and thanked Ben for his advice. Is there something more I need to do to "select" his solution? This is my first post here, so I'm still finding my way. I certainly do want other members to know what worked.
by
it isnt a seating problem for me because it turned on after the installment
by
Add a comment
Connect to computer, if the iTunes doesn't recognize,press and hold the power button and Home button at the same time until you see the Apple Logo.
Score 2
Add a comment
Add your answer
kthyne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,416
