Whats possibly wrong with my Touch ID?
I cracked my screen and got it repaired at a local kiosk. Replaced my screen (albeit with a very crap, dim one with horizontal lines) and got Touch ID to work with this crap quality screen.
Not being happy with the quality of the screen, I bought this from Replacebase and installed it myself, moving over the home button.
https://www.replacebase.co.uk/for-apple-...
After installing this, Touch ID suddenly failed. Even putting back the crap screen - where it had worked before - failed! After getting refunds, I went to a professional service and got the screen replaced by quality parts but still no Touch ID. The add fingerprint section is greyed out and I keep getting the pop up saying unable to activate.
Interestingly I went to an AASP and they ran a diagnostics which immediately gave a error regarding Touch ID. What could have happened and why is it not working at all now when it once did ? Is there a way to fix this before forking out £300 with Apple :(
Thanks
2 Comments
@teetopp Thanks for the answer. Come to think of it, the socket for the home button cable was very loose when I was attempting to disconnect the home button from it. Could that have been a problem? This piece was actually glued down before. Im guessing the home button would not function properly (excluding Touch ID) if there was damage to the actual home button's cable? I will try find a metal shield.
by Dipesh
There is an adhesive that holds the ribbon cable to the "Back Plate", as well as an adhesive that holds the "Socket" to the plastic frame of the phone to keep it from moving. You could use a bit of heat next time (Not too hot) to loosen the adhesive to allow it to lift without damaging the fragile flex.
Here is a link or 2 to the part I am mentioning... Just for reference purposes, these are just random picks to describe the part.
http://www.ebay.com/itm/like/15214757636...
https://www.fixez.com/iphone-6-plus-home...
You do not need the metal plate, as you have one if you can find a new flex caple to adhere to your back plate :)
by The Microsoldering Shop
