https://www.repairclinic.com/RepairHelp/...
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Part Testing
Parts
Thermal Fuse for your KenmoreDryer
Thermal Fuse - Part # 2651 Mfg Part # 279816
RepairClinic Item #2651
Dryer heating element thermal cut-off (thermal fuse) 309 degrees and high limit thermostat 250 degrees, with wiring kit. If the dryer does not heat the thermal cut off may have blown and a new high limit thermostat is needed.
$27.15
Quantity:
In Stock ›
Suggested tools
Multimeter
RepairClinic Item #964740$20.57
Multi Screwdriver
RepairClinic Item #3527472$15.70
Same Day Shipping
Order by 8:00 PM ET, this part ships TODAY!
365-Day Return Policy
Return any item for any reason within 365 days of placing your order.Find out more »
Total: $27.15
ADD TO CART
Cause 2
Thermal Fuse
Part Testing
Parts
Thermal Fuse - Part # 2986 Mfg Part # WP3392519
RepairClinic Item #2986
Dryer thermal fuse located on the blower housing. If the dryer overheats, the thermal fuse blows cutting off power to the motor or the heating system. When the fuse is bad the dryer won't start or will run but not heat. The thermal fuse cannot be reset. Fuses often blow due to a clogged dryer vent.
$9.39
Quantity:
In Stock ›
Suggested tools
Multimeter
Multi Screwdriver
Same Day Shipping
Total: $9.39
ADD TO CART
Install Help
Cause 3
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Parts
Start Switch for your KenmoreDryer
Start Switch - Part # 528548 Mfg Part # WP3404233
RepairClinic Item #528548
Push to start switch. NOTE: If the dryer will not start check the thermal fuse before ordering the start switch.
$26.71
Quantity:
In Stock ›
Same Day Shipping
Total: $26.71
ADD TO CART
