Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Why does my iPhone 5 switch on only when connected to its charger?
Basically my iPhone 5 would not turn on at all if it is not connected to the charger even though it has full battery. The phone will only switch on when connected to its charger even though the battery is full. Why is this so? Thanks
Add a comment
Chosen Solution
Probably needs a new battery. You can get a good one for pretty cheap on Amazon.
Score 2
1 Comment:
Thank you very much Adam!
by
Add a comment
have you check if you can switch it off and then switch on again from power button while it's charging? if yes than sign of battery... but if no sign of power button.
1 Comment:
No need to check that. It's a issue caused by battery.
by
Add a comment
Add your answer
Abbhilash will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 39
