1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Update with battery missing
Greetings Community,
my MacBook Air says that its battery is missing indicated by the x in the battery symbol. I reset it as I thought it would probably fix it. Now I'm stuck on lion as I can't perform an update. When I want to, it says connect to the ac adapter, which it obviously is. Now my question, does anyone know how to bypass this, so I can update the macbook?
And I won't change the battery as I will buy a new laptop in a year for university.
I plan on using the Macbook as a media center plugged into my TV.
Thank you in advance.
Add a comment
1 Answer
Most Helpful Answer
Some how we need to get the battery working before you can do the upgrade.
Lets give this a try to check your battery and the battery charging logic: CoconutBattery.
Score 1
Add a comment
Add your answer
Jakob Buchmeier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 78
