Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
How to replace keyboard
Hi,
Is it possible to replace the keyboard from my macbook pro from qwerty to azerty?
And does anyone know if I can use the keyboard from my older A1278 (macbook unibody 13" late 2008) or do I have to buy a new one?
Thanks in advance!
Add a comment
Most Helpful Answer
You don't need to replace the keyboard, only carefully lift the key caps and then re-align them to the altered pattern.
Here is a vid on doing this: How to remove and clean Macbook Pro keyboard keys that is if you want a permanent setup. Or, use a cover like this one: French (AZERTY) Keyboard Cover which is what we do.
Now the fun part! You'll need to find the needed keyboard layout driver for the other keyboard pattern or create your own. Here is how you can get to the Apple supplied layout drivers: How to change the keyboard language in OS X
Score 2
2 Comments:
Your Keyboard Cover link is broken, might wanna verify it’s the correct link. :-)
by
@tronke - Keep in mind this post was over 2 years ago! I don't control their web site. Here's the current listing: https://kbcovers.com/french-azerty-keybo...
by
Add a comment
MacBook Pro 13" Unibody Mid 2010 Keyboard Replacement
that works!
Add a comment
Add your answer
Erwin Cornelis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 870
