1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Questions View all
Upper case bulge from battery expansion
the upper case is bulging from battery expansion. the apple store personnel said no parts are available for them to do it, but aftermarket repair is an option. they gave a caution tho that many parts need replacement, not just the battery. i see in the battery replacement comments that once the cover screws were removed the upper case flattened out and was ok, but is that the normal response or do i really need to replace more than the battery?
Add a comment
1 Answer
Chosen Solution
Hi!
Depending on how bad the bulge is, you may or may not need to replace the palmrest as well. You can remove the battery from the system without having a replacement ready to see if the case will flex back to normal.
Here's how to do it: MacBook Air 11" Mid 2011 Battery Replacement
Score 2
1 Comment:
thank you, i will try that first and take it one step at a time
by
Add a comment
Add your answer
robert cipoletti will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 336
