1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
Power won't charge battery issue
#1
I have a 13" 2012 MacBook Air. When I plug in the power cable the LED does not light and the battery does not charge. However, if I remove the battery connection from the logic board, the LED lights. When I re attach the battery to the logic board it charges. If I remove the power cable and reattach it, while its charging the LED will not light and the battery will not charge. I've tried changing power cables (with a brand new charge and the problem remains. I've tried to reset the PRAM AND SMC several times and the issue remains. I'm at point where I either try replacing the battery or the logic board.
My thoughts, since the power cord does charge the batteries, the it cannot be a connection issue. Also the USB and headphones work without issue. I have a feeling the issue is simple but I'm not sure. Replacing the battery is cheap but the logic board, is cumbersome as well as $$$.
Any ideas? I appreciate the feedback.
Update (08/26/2017)
For the record, I let it charge to 100% then I reattached the battery cable. CoconutBattery states that the power is not connected, even though it is...
Add a comment
Chosen Solution
The fix was replacing the logic board. I brought it to the Apple Store where we diagnosed the issue. I purchased a logic board online and boom! It works! YES!
Add a comment
Most Helpful Answer
Let's get a better look at what is going on. Please download, run and post your results with Coconut Battery.
http://www.coconut-flavour.com/coconutba...
UPDATE
Thanks for the battery info. It looks OK.
Has anything happened to the machine, a spill or a drop? Are you the original owner?
Score 1
1 Comment:
MacBookAir5,2
Manufacture date: 2013-04-15
Current Charge 3939 mAh
Full Charge Capacity 5638 mAh
Design Capacity 6700 mAh
Manuafacture data 2013-03-22
Cycle Count 606
macOS Battery status Good
Battery temp 31.9 C
Charging with 23.83 Watts
Power adapter Connected.
Battery Man. Simple
Age 1618 days
Battery Failure None
Now, I'm charging the battery now. But I had to go through the process above to do it.
by
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,565
