THINKPAD T520: Top Tier Performance and Portability.
17 Questions View all
Screen is too blue
Lenovo T520 running Windows 10 pro. It's not the Blue Screen of Death, it's that areas that should be white are blue, and the resolution is poor. Periodically corrects itself for an hour or 2. This has happened before, and preceded a hard drive crash during a system update. Following the crash,the hard drive can't be recognized and has to be formatted. The second time, I replaced the hard drive but it didn't solve the screen problem and again crashed on updating. That time I restored to Windows 7 with the factory recovery disks. It hasn't crashed yet (3 days) but the screen is still too blue most of the time. It passes all the diagnostic tests except the one where the screen should be all white (it's blue). The problem is present on the splash screen when booting up, which I'm told means a hardware issue. I've read that for people with desktop systems this problem is sometimes the cable. So finally the question: should I open up the laptop and mess with the cable? Any other ideas?
Thanks a lot!
Update (08/27/2017)
So I removed the LCD screen and, obviously, detached that end of the cable, and I've exposed the other end of the cable, but I'm not sure how to detach it. Does it just slide out the screen end, or do I have to release some clip or something? Please see photo. Thanks!
It works! I cleaned both ends of the cable and both connectors, put it back together and it booted up normally. It's been fine all day and I think it would have reverted to blue by now if it was going too. Many thanks!
1 Comment
I think you have to lift the black bar (like a clip) up and pull out the cable.
by
Add a comment
1 Answer
Chosen Solution
Yes, I think you should definitely open it up. We do have a guideon how to upgrade the display, but it should get you to that flex image cable.
Once you get to it, unplug it at both ends, take a good look at it (make sure there is no physical damage), clean the contacts and reconnect it.
You could also tinker with the Windows Display Color Calibration utility, turn the blue levels down and see if anything changes.
If reinserting the cable and reconfiguring the display does not yield any positive result, you should replace the flex cable.
Score 2
1 Comment:
Thank you! I will try cleaning the contacts and reconnecting the cable. New info: I connected the laptop to an external monitor and the color and resolution are fine! That seems like good news. However the issues of the HD crashing on updates is still a question. It seems to be associated with the too blue screen problem, but does that make sense? I'll report back after the cable adventure.
by
Add a comment
Add your answer
William Clarke will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 39
All Time: 2,585
