Water damaged What to do now?
The phone is badly waterdamaged amd im going to try to put it in isoprpyl alcohol but i dont know if i should put the whole phone in the alcohol or just the motherboard.
Remove the logic board and put that in IPA. Don't put the screen or cameras as you may cause additional damage:
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
