RAM memory Slot Issues, only 1 works
I just got a new 2x4GB ram upgrade for my macbook pro.
After I switched the old ones for the new ones, I turn it on and the machine starts beeping. I figured was a problem with the ram.
I thought the new memory was incompatible with my macbook. So I switched back to the original ones, and there comes the beep again.
So I took the bottom memory stick off and leave it with the upper one only. The machine turns on fine. I figured the bottom slot was damaged or something like that.
But then I switched the ram, I put the one stick on the bottom and leave the one on the top empty, and it turned on just fine.
So everything works fine as long I use only one slot, either one, doesnt matter.
1 Comment
Please tell us the numbers on the new RAM and the source that you got them from.
by mayer
