Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
I have colored vertical lines on my screen, how do I fix it?
My iPhone 6s was previously cracked, but I dropped it again and now my screen is 80% vertical colored lines. The whole thing is unresponsive, do I need to replace the LCD or ? I just don't want to buy the parts and it still not work.
Score 1
Add a comment
Chosen Solution
Most likely, it is just the LCD that needs replaced. But you can open it back up, make sure you power phone off and disconnect battery...then reseat the connector to verify it is same or not. If it still has the lines, replace LCD...Always disconnect power before disconnecting or connecting the flex cables to it
Score 3
Add a comment
Yes you need change Lcd.
note : same problems must upload image because we give 100% Right Solution
Score 1
Add a comment
Add your answer
Danielle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 1,309
