Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Questions View all
Question Closed
Boot loop caused by possible hardware issue?
I have an iPhone 7 plus that a person gave to me to repair. The person supplied their own screen (which I dont care for). I noticed right off that someone tried to repair the phone, because when I opened it the touch and lcd flex were torn and the camera flex was stretched. I replaced the screen and everything worked. It worked all night and I left it charging. The next morning it was still working just fine. I rebooted it several times to triple check everything. I always test calling, touch, camera etc. When I was driving to drop it off, it randomly rebooted, then went black then back to the apple logo. I tried to do a hard reset several times. Nothing worked. So, I tried to do an update and restore through itunes. I was still in a boot loop. So, then I started to work backwards. I unplugged the camera flex and it booted fine, but the home button wasnt working. When I plugged the camera flex back in, it boot loops. I go home to swap the camera flex with a new one. I get the same result. If I leave the camera flex unplugged, it boots. The home button at this point is non functional, so Im past that. I just want to know if this sounds like a board level issue at this point? Or maybe I should try another camera flex (I'd need to order one) to rule out having a bad original part and replacement part?
I know this was a lot of info. I hope I explained everything clearly.
Score 1
1 Comment
Any one else have any suggestions? I believe at this point it's a board level issue. I just want to make sure before telling the customer.
by
Add a comment
1 Answer
Most Helpful Answer
You sure you didn't just plug the camera flex ribbon cable upside down? It sorta folds then plugs in.
Score 2
1 Comment:
No, I didnt. I've repaired a lot of iPhone 7 and 7 plus screens, so Im always careful when plugging flex cables in. I make sure I get that sink feel as it slides in place before snapping it in.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,112
